atlanta30328
Jun 17, 2016Aspirant
ReadyNAS NV+ version 1 stuck on boot screen
Hello, love my ReadyNas NV+ version 1 for many many years. This morning it is stuck on boot. Running Xraid and memory maxed out. Unit boots up fine and the LCD display on the unit shows: ...
- Jun 24, 2016
Yes speed is one thing, but really I like fiddling with technology and the NAS is one of those areas I like. I use it for music delivery to wifi speakers and file/photo central storage. In reality, no one in my family is complaining about speed, but it's a convenient excuse :smileywink:.
Jun 17, 2016Guru - Experienced User
What paper-clip option did you chose? One is destructive.
The one that you probably should try is "skip volume check" - page 23 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
Did you check the activity light on the NIC interface?
