wagwarnas
Jan 03, 2025Aspirant
ReadyNAS NV+ with 4 x 1TB drives
I’m using my ReadyNAS NV+ for my Sonos music library. A recent upgrade to my Sonos app revealed a problem reading my music library on my nas. Sonos requires SMB 2 or 3 support. I believe my nas suppo...
Jan 03, 2025Guru - Experienced User
wagwarnas wrote:
I’m using my ReadyNAS NV+ for my Sonos music library. A recent upgrade to my Sonos app revealed a problem reading my music library on my nas. Sonos requires SMB 2 or 3 support. I believe my nas supports SMB 1/ CI FS. How do I update my nas to SMB 2 or 3?
I am thinking you have the original NV+ (running 4.1.x firmware). That's a really old NAS. You can't update it to use SMB 3. There is a setting to enable experimental support for SMB 2. No idea if that will be enough for Sonos.
See post 2 here:
wagwarnas
Thank you for your response. I think that solution is beyond my pay grade. I don’t know even how to get to etc/.
- StephenBJan 04, 2025Guru - Experienced User
Does the Sonos S1 controller app work?
- wagwarnasJan 04, 2025Aspirant
No. I have the same problem. I get a Sonos 913 error when trying to add my music library. Sonos tech support told me SMB 2 or 3 is required now.
