monkeyass's avatar
monkeyass
ReadyNas NV+ Wont Boot
Hi
My ReadyNas NV+ developed an issue where by It kept getting stuck at the boot stage. For a while it worked by skipping the volume check, but now also gets stuck here. I only need to boot the NAS on final time to transfer the large amount of data over to my new NAS. Does anyone have a solution?
Thanks
  • StephenB's avatar
    It might be possible to manually mount the volume using tech support mode.  Have you ever used linux?
    • monkeyass's avatar
      monkeyass
      Yes, briefly in the past, not sure when I used it last.
      • StephenB's avatar
        Unfortunately, the normal commands to mount the volume manually are likely to fail (since something is obviously wrong). If that's the case, then we can't help much in the forum.
        If you can connect three of the disks to a PC (either SATA or with a USB adapter/dock), then you could use RAID recovery software to offload the data.  R-Studio is a reasonable option. https://www.r-studio.com/
        But here are the basic instructions:
        After booting the NAS in tech support mode, you access it with telnet (not ssh).  Log in as root - the password is infr8ntdebug.
        Then use the following commands:
        # start_raid.sh
        # mount /dev/hdc1 /sysroot
        # mount --bind /proc /sysroot /proc
        # mount --bind /dev /sysroot/dev
        # mount --bind /dev/pts /sysroot/dev/pts
        # chroot /sysroot /bin/bash # vgscan # vgchange -a y # mount -o ro /dev/c/c /c
        These start RAID, mount the OS partition, chroot, and then mount the data volume as read-only.
        You could then mount a USB disk (no larger than 2 TB) and copy off files with linux commands.  You could also run rsync manually to push data to the new NAS.
ProSupport for Business
