paulhenman
Aug 09, 2016Aspirant
ReadyNAS NV+ won't turn on - power supply issue? #27356934
I shutdown my NV+ on Friday night, expecting a large storm while I was out. Tried to power on Saturday morning ubt NV+ not responding - no lights on front panel. I tried tapping the power button, wi...
- Sep 06, 2016
Hello paulhenman,
New RMA for PSU replacement has been shipped today. Please update once received.
Aug 09, 2016Guru - Experienced User
It doesn sound like the PSU. You could try calling netgear support, and see if they have any inventory.
There is a range of serial numbers that had a PSU service action, and those units are covered even if they are out of warranty.
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
If it's the unit on your profile the serial is not in the range.
You could try and find the RND4PSU1-1000S. It is also possible to rewire a standard ATX PSU to work (though it may not fit in the case).
You could also choose to get a new ReadyNAS and follow this procedure: http://kb.netgear.com/app/answers/detail/a_id/29876/~/readynas%3A-migrating-disks-from-raidiator-4.1-or-raidiator-5.3-to-readynas-os-6
