kenlee68's avatar
kenlee68
ReadyNAS NV+ [X-RAID]
Hi,
I have an old ReadyNAS NV+ [X-RAID] and have movies files saved on it a long time ago, there are some over 4G size and I am not sure how I copied it over, I am trying to get it off to my computer or to another NAS but failed because the size is larger than 4G too big.  Any ideas how I can take these 11G files off?
It's also strange it's reporting the size used, as I have an near identical backup on another NAS which has taken over 1T but the Netgear NV+ tells me it has only used 406G, how can that be.
Thanks
  • StephenB's avatar
    This sounds more a PC problem, not a NAS problem. Are you trying to copy the files to a drive formatted with FAT32?
    But you should be able to copy to another NAS.  What model NAS is it, and how are you trying to do the copy?
    • kenlee68's avatar
      kenlee68
      I have tried to copy the file on the Netgear NAS to my Windows 10 Enterprise 64bit PC, the drives are formatted to NTFS, an error code pop up and when I looked up the code, it said to change the register on my PC so it can copy the files.  But the registery can only be set to hex-decimal ffffffff and can only handle 4G file size
      I tried dragging it from one mapped NAS windows to the other mapped NAS windows  but same error, the other NAS is an old Synology 1010+ too but that one I can copy a file over 4G from my PC to it and copy it back down to my pc.
      So not sure how I got the big files on the Netgear, just want to make a copy to the Synology.
      • kenlee68's avatar
        kenlee68
        Hi all,
        I have worked it out, I turn on ftp and use that to transfer the files over.
        Thanks
ProSupport for Business
