cathcam
Jun 29, 2022Guide
ReadyNas NVX 4-bay x2TB
Had a couple of drive failures recently, amazon had a deal on 2TB Seagate Barricuda drives. Copied all the data to a backup readynas, removed the old drives and replaced with 4x new drives. Power...
Jun 30, 2022Guru - Experienced User
cathcam wrote:
At least as far as I'm aware, the NVX is OS 4 and has a max capacity of 4x 2TB drives on this model. 4TB drives are not supported?
Yes to OS 4, and no to 4x2 TB max capacity.
The capacity that Netgear advertised is generally based on the largest available disks at the time the datasheet is published. They rarely go back and revise that as disk technology uses.
There are challenges with OS 4.2 systems going over a 16 TB volume size, and there is an expansion limit of 8 TB over the volume starting size.
But there is no particular limit for each disk size. So you could use 3x8TB drives, and get a 16 TB volume. Though I haven't seen any posts from NVX owners on this, getting 4x16TB drives and setting them up as two 16 TB RAID-1 volumes should also work.
cathcam wrote:
Since this NAS is only used for longterm storage, archiving, I'm ok with the choice/price/performance of the barracudas. Also, both the primary and backup ReadyNAS NVX are over 14-years old, neither support TLS 2.0 and really should be replaced, but meh, I'm ok with it now especially as the primary is also backed up to the cloud.
There is an add-on from WhoCares_ (who runs rnxtras.com) that will add TLS 1.2 support to your NAS. That will allow connection from current browsers that have dropped support for TLS 1.0. A direct link to the add-on is https://github.com/rdynsxtrs/rn4bin/blob/main/apache2/x86/Apache2_2.2.34-x86-0.2.0.bin
cathcam
Jun 30, 2022Guide
Yes, I saw the WhoCares_ solution, but since I'm no specialist, decided running a backlevel Firefox browser for the rare times I needed to access the ReadyNAS is just as easy. I'm also totally dependent on Microsoft not dropping support for SMB1 in Windows 11. It's still there but I'm sure that will go at somepoint and that will be the deciding factor on getting a new NAS.
I don't hang out here often enough to be able to benefit from the perceived wisdom. It's good to know I could actually get bigger drives if I needed them. Since I've never filled the circa 6TB I get from the 4x 2TB running in RAID5 thats never been a consideration. When I do, it will be time to rethink my whole setup and get servers that were designed in the decade I'm in.
Appreciate the time you took to respond. All interesting stuff!
++Mark.
