blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
May 09, 2012Guru - Experienced User
Did you enable jumbo frames on the switch? It is a managed switch with its own web page for configuration.
