blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
blue_max1
StephenB wrote: Did you enable jumbo frames on the switch? It is a managed switch with its own web page for configuration.
Thanks for the quick response Stephen.
I have set the maximum frame size to 9000 under >port configuration. I have sleep mode and short cable mode to disable, but link trap to enable.
My LAG settings are: link trap - enable, admin mode - enable, LAG type - LACP and shows link up.
I have fixed IP addresses to all devices. My default gateway is my router (fixed again). IPv6 off in all cases.
Hope something there gives a clue.
Thanks again.
Graham
