blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
May 09, 2012Guru - Experienced User
You might need to raise the max frame size on the switch, since I think it includes the ethernet framing (unlike most NICs configurations). Note the minimum is 1518. Perhaps try 9018. (or a bit higher if you use vlans).
Are you seeing anything in the port statistics? You could also try using ping to probe the mtu on the connection path from the PC to the NAS.
BTW, I run with jumbo frames off, so there could be some limitations I haven't run into here.
