blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
blue_max1
Well, I tried that and no go (went to the max of 9216). Again, when I check the 'use jumbo frames' checkbox on the nas config screen it seems unhappy. After a reboot, I can't access the admin page of the nas (It goes to a blank page with no choices on the left). I have to go into the switch settings and disable the members of the LAG. Then all is well again. I can use raidar to confirm that it is seen on the fixed ip address as expected, so I'm really confused.
I appreciate it may make no difference, but I have invested in a new switch by the same manufacturer and can't believe they won't play together. I'm just hoping I have made a simple mistake in one of the settings. But which one? I'm on a mac and most of this is going straight over my head - the gs108t gives a huge number of esoteric settings with very limited explanations and none that mean anything to me.
Hope someone can shed some light on what might be happening.
Graham
Graham
