blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
May 09, 2012Guru - Experienced User
Did you enable global flow control on the GS108T? It is on by default on a new unmanaged switch, but is off by default on the GS108T. Lots of things don't work well if flow control is off.
Did you attempt to use ping to probe the mtu?
You could also try some intermediate MTU sizes on the NAS (maybe start with 3000)
