blue_max1
May 09, 2012Aspirant
ReadyNas NVX and GS108T Jumbo Frames
I decided to try teaming the cat6 cables on both my NVX and have a problem. Previously I had a mac/gs108/NVX all with jumbo frames active at 9000. Now I just bought a gs108T and teamed a couple ...
May 10, 2012Guru - Experienced User
Jumbo Frame settings determine the MTU (in your case you are expanding the MTU to 9000 bytes by turning jumbo frames on). Though if there is an issue, the packets are generally blocked or fragmented.
http://muzso.hu/2009/05/17/how-to-deter ... icmp-pings has a mac example on how to measure the actual MTU. You might try this first with LACP turned off, since that appears to be stable.
