syspike
Oct 08, 2015Aspirant
Readynas NVX exhibiting weird behavior
My readynas NVX has been working for years without any issues. Last night something happened where all the shares became inaccessible. Further investigation shows that the file protocols ...
- Oct 09, 2015
Crashplan created the problem. The files you need to delete are in /usr/local/crashplan/upgrade. I sent you a PM.
Take a look at https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/985781#U985781 That will give you the information you need to update java once you get the NAS up and running.
syspike
Oct 09, 2015Aspirant
actually i do have crashplan installed but it hadnt backed up in a few days and i was investigating why the day before the issue occured. i currently have the drives mapped to a windows pc and using ufsexplorer appear to see the raid and folder structure. Where would i be looking for those temp files, perhaps i can mount the raid and manually delete them, then pop it back into the readynas.
Oct 09, 2015Guru - Experienced User
