d3l
Mar 08, 2017Follower
Readynas NVX on boot loop
Hello, Got a power cut off, readynas wont boot, stuck on 'booting' forever. OS re-install from boot menu wont work and neither does the the USB recovery. Can someone help me out with remote c...
JennC
Mar 08, 2017NETGEAR Employee Retired
Hello d3l,
Do you have backup of the data? It is always strongly recommended to always have full backup of the data as storing important files in one device is not really a good idea.
I suggest you try Skip Volume check instead from the boot menu, Once you are able to access the files/NAS, back up. Then check the disks for reallocated sector count and pending errors, most importantly, the ATA errors.
Welcome to the community!
JennC
Mar 10, 2017NETGEAR Employee Retired
Hello d3l,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
