carpii
Dec 04, 2014Tutor
ReadyNas NVX Power Supply #24307644
Hi all, The PSU on one of my three ReadyNAS seems to have died overnight. Its an NVX model (Netgear portal lists it as ReadyNAS RNDX4000) How can I go about getting a replacement for this? Is t...
mdgm-ntgr
Dec 04, 2014NETGEAR Employee Retired
Yes you can migrate the disks from the NVX or even e.g. to a Pro 4. I wouldn't migrate the other way from the Pro 4 to a NVX however.
Best to make sure the replacement NAS has at least as new firmware on it as what the old unit had first. Best to keep the drive order the same.
