rsilva1
Nov 11, 2012Aspirant
ReadyNAS NVX problems replacing disk
Hi, Yesterday I received a notification that one of the disks in my ReadyNAS NVX was dead and required replacement. I had a spare disk of the same kind (it is the 3TB Hitachi that is listed in the...
mdgm-ntgr
Nov 11, 2012NETGEAR Employee Retired
You are running 4.2.16 or later so your disks would use GPT not MBR. fdisk is for use with the MBR partitioning scheme only.
So do e.g.
What brand and model disks are these?
So do e.g.
MDGM-NAS:~# sgdisk -p /dev/sdc
