rsilva1
Nov 11, 2012Aspirant
ReadyNAS NVX problems replacing disk
Hi, Yesterday I received a notification that one of the disks in my ReadyNAS NVX was dead and required replacement. I had a spare disk of the same kind (it is the 3TB Hitachi that is listed in the...
PapaBear1
Nov 13, 2012Apprentice
When it said disk failed, did it give you any message either on the front screen or in the logs? On some instances the disk may actually be fine, but it may be one sector smaller than the previous smallest disk and will therefore be rejected as being too small. I have hit this several times on some of my 1TB Seagates and on a 500GB Samsung previously.
The only cure I know for it is to back up the entire volume, insert the disk and then perform a factory default. The only preventative I know of is that when you establish the volume and before you add data, is to swap out a known good disk with the one you are going to keep as a spare. Then if you get this message, you can simply factory default and use the good disk that had been removed as a spare.
