rsilva1
Nov 11, 2012Aspirant
ReadyNAS NVX problems replacing disk
Hi, Yesterday I received a notification that one of the disks in my ReadyNAS NVX was dead and required replacement. I had a spare disk of the same kind (it is the 3TB Hitachi that is listed in the...
rsilva1
Nov 13, 2012Aspirant
I must admit I did not check the logs. Since I have a spare disk, I inserted that one and connected the "failed" one to my PC for diagnostics.
I have just noticed that /var/log/messages on the NAS has not been changed since 30 April, despite the unit being on 24/7.
At the moment, syslog only goes back 2 days and the failure was on the 10th... logrotate does not seem to be working (despite being in cron.daily). There are a syslog.1 and syslog.2 files, but they are zero-length and a few months old...
As for the new disk being smaller, hdparm reports it to have the exact same number of sectors as the other three, so I don't think that is the issue.
When I explicitly inserted a smaller disk (to make sure the system was able to recognise the new disk), I got a message saying it was too small.
Netgear support recommended reinstalling the OS, so I will try that before performing a factory default.
/var/log# hdparm -I /dev/sda | grep -i sect
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 5860533168
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
R/W multiple sector transfer: Max = 16 Current = 0
/var/log# hdparm -I /dev/sdc | grep -i sect
sectors/track 63 63
