consumedsoul
Apr 20, 2014Aspirant
ReadyNAS NVX to Pro?
Hi all - apologies if this has been asked already (searched and couldn't find the exact answer) - I currently own a ReadyNAS NVX w/ about 3 TB of data - and after an apartment move the unit won't powe...
mdgm-ntgr
Apr 20, 2014NETGEAR Employee Retired
A 4-bay or 6-bay Ultra/Ultra Plus/Pro would be fine. Provided your disks and array are fine the migration should work.
You should put a spare disk (must not be from your array) in the replacement NAS and update the firmware to at least as new as what you were running on the NVX.
