consumedsoul
Apr 20, 2014Aspirant
ReadyNAS NVX to Pro?
Hi all - apologies if this has been asked already (searched and couldn't find the exact answer) - I currently own a ReadyNAS NVX w/ about 3 TB of data - and after an apartment move the unit won't powe...
consumedsoul
mdgm wrote: A 4-bay or 6-bay Ultra/Ultra Plus/Pro would be fine. Provided your disks and array are fine the migration should work.
You should put a spare disk (must not be from your array) in the replacement NAS and update the firmware to at least as new as what you were running on the NVX.
Awesome, thank you so much for confirming!
