dtarin
Jun 13, 2016Luminary
ReadyNAS NVX will not power on
Model: ReadyNas NVX 4220 Firmware: 4.2.28 Issue: no power I had to move my ReadyNAS NVX and I powered it down successfully. I opted to have it do a scan on next power up. Later, when I ha...
- Jun 13, 2016
Yes, the NVX uses a Mini-ITX, aka Flex ATX, form factor power supply like that one; and you do not need, nor is there room for, an extension cable. It does have a different pin-out, even though it has a standard looking ATX connector, so be warned. Search the forum for "legacy power supply" for a more complete message from me and use the pin-out from the reply (original link is no longer valid). That 250W one does have sufficient 12V power per the listed specs.
dtarin
Is there a guide on how to remove the power supply? I attempted to dismantle the nvx but I can seem to figure out how get to the power supply.
