samuk
Nov 17, 2011Aspirant
Readynas or Buffalo? - URGENT
Hi, Why would you buy a Readynas Ultra 4 over the Buffalo Technology LinkStation http://www.amazon.co.uk/Buffalo-Linksta ... 243&sr=8-4 Maybe a simple answer - please let me know ASAP. I a...
sphardy1
Nov 17, 2011Apprentice
PapaBear wrote:
Will the Buffalo support drives larger than 2TB? The new Duo v2 (and NV+ v2) will and of course all the Ultras and Pros do as well.
Yes - a 6TB model is fully available. Based on the specs on the Buffalo pages, that appears to be the only significant difference vs the Duo v1. While the Duo v2 solves that limitation it doesn't actually appear to be available yet so that might not really be an option if the end user is in a hurry to buy
