Varatex's avatar
Varatex
URGENT/11 and Netgear Switches
Hey everybody,
Does anyone know if Netgear uses VxWorks on their switches?  A quick Google search makes it sound like they've at least used it in the past for some of their equipment.  I was hoping to understand if this was standard or not and if VxWorks is implemented, could a Netgear rep tell us when we will expect to see patches for the Urgent/11 volnerabilities that were disclosed just a few days ago?
Thank you!
  • @Varatex,
    NETGEAR constantly monitors for both known and unknown threats. Being pro-active rather than re-active to emerging security issues is fundamental for product support at NETGEAR.
    Kindly check the link below for upcoming updates:
    NETGEAR Product Security Advisory
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Varatex,
    Welcome to the community! :)
    Can you provide a specific NETGEAR switch model/series that you are referring to then I will inquire it to the higher tier of NETGEAR Support.  I'll post here once I got a feedback.
    Were you able to check if your NETGEAR device/s are affected by the Urgent/11 vulnerability?  If yes, what test/s did you perform that shows that the NETGEAR device/s you have are affected by the Urgent/11 vulnerability?
    DaneA
    • Varatex's avatar
      Varatex
      Hi DaneA!  Glad to be here
      I put the models we have in the original post, see below:
      Model: FS728TPv1|28-Port 10/100 Fast Ethernet PoE Smart Managed Pro Switch with 24 PoE Ports, GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports, JGS524E|ProSafe Plus 24 ports gigabit switch, JGS524Ev2|ProSafe Plus 24 ports gigabits switc, GS324
      I haven't been able to test since I'm not too sure how.  I was going to assume they are affected if they use VxWorks but I was hoping to get some sort of confirmation from Netgear.
      Thanks for your help!
      • Varatex's avatar
        Varatex
        Hi everyone,
        Just following up on this topic.  It's important.
        Thank you,
ProSupport for Business
