tigerten
Jan 28, 2024Luminary
ReadyNAS OS 6.10.10 released
Link to download:
https://www.netgear.com/support/product/readynas_os_6#download
Release Note:
https://kb.netgear.com/000065999/ReadyNAS-OS-6-Software-Version-6-10-10
Cleaned up a bit. BUT Still not detectable from within ReadyNAS OS web interface. This is stupid. Who would come check regularly?
I have not upgrade yet. like to wait and see how it goes. I don't quite understand what it means by "application function" removed.
- tigertenLuminary
1. ReadyCLOUD is gone, which is good.
2. Previous problem of not being able to install apps because of obsolete repository is now fixed by not allowing to install apps, Cool!
3. The "Apps" tab is still there though, for what, a future return?
4. The update is still not being pushed to clients automatically.
For me, not able to install apps is no-no.
I will stay with 6.10.8 or 6.10.9, which are basically the same.
- sharmyApprentice
tigerten wrote:For me, not able to install apps is no-no.
100% agree.While I understand that Netgear has decided to exit the NAS segment, this should not be reason to remove critical features important to those who purchased their hardware. Even worse, many users will have units that are still "relatively" young (less than 5 years old). Netgear - you must do better than this.
- tigertenLuminary
ReadyNAS is now truly in a stage of DNR. Netgear has already started withdrawing care of and euthanizing ReadyNAS.
Worst company I have ever owned product of.
- etonLuminary
"The Apps installation function is removed from the Apps section on the System page (also referred to as Overview page) of the Admin Page."
What?
Although this should not come as a surprise, since is ReadyNAS have been abandonware for a long time.
- SandsharkSensei
This doesn't surprise me, since the changes necessary to allow app upload with Debian Jessie do present a potential (but, IMHO, manageable) risk. Netgear could be setting themselves up for a lawsuit if they implemented them in an official release.
But now, if they release something beyond 6.10.10, everyone is going to have to decide if losing app capability is worth whatever other change they make.
If they ever do put 6.10.10 on the upload server, then the forum will likely be inundated with people wondering what happened to the app upload capability, even if they have no immediate need for it.
- b1jzcbxTutor
i attempted to put my RNDP6000-200 under "associated products" but it said "could not find product.." so..?
Has anyone tried installing the latest debian kernel?
it would be fantastic if a pro were to install just the basic, debian kernel, no gui or any of the crap.. then install "the cockpit" (from the cockpit project" as the web ui..
Is it possible to install it in the onboard dom or will it have to go on the drives? sorry, i'm a novice and not completely sure how the whole thing works.
i know you can install the zfs module.. would be great to install basic, stripped down debian, the cockpit, and then from there create a raidz2 array across the drives and be able to move on..
rndp6000-200
xeon cpu (from back in the day when intel had one that could replace the 2 core that the original nas came with, I don't remember which one),
8Gigs ram.
- SandsharkSensei
On a legacy ReadyNAS, the flash is not a DOM. Except on some rack-mount units (where it's a standard USB flash), it's a soldered-in chip. It may still use a USB-like interface (I simply don't know), but you can't expand it. If it is USB-like, then it would also be USB2. It may also not be rated for the number of writes you'd normally do with a standard Linux install. So putting a full OS on it is a really bad idea, if it would even work.
The Pro6 has an internal VGA header. With the right adapter, you can connect a monitor and you can use a USB keyboard, so you can basically install anything you want on the drives, even Windows. It basically behaves like a 6-bay generic Intel PC of it's generation.
- b1jzcbxTutor
yes, i have the vga header installed. i've updated/upgraded my readynas as far as it'll go, as far as i know. its currently running readynas OS 6.10.8. it doesn't see the later versions when i do an 'update'.
also, i was hoping to get away from btrfs.. it sucks. the perpetually unfinished filesystem. i've had a few too many files disappear on me only to find out there's a known flaw in it.
i read some article about some guy who loaded freenas on a USB and was able to install it fully on his readynas, but i'd prefer to have a proper os drive to install on.
thought it would be a nice way to keep the little guy going.. for simple file storage it would be fine as a backup.
It would be best at this point for Netgear to just release instructions on how to load your own OS on the hardware if you want as part of a "recyclable and reusable End Of Life and Support" plan or something.
- givememynamebakLuminary
good4y0u wrote:It would be best at this point for Netgear to just release instructions on how to load your own OS on the hardware if you want as part of a "recyclable and reusable End Of Life and Support" plan or something.
good4y0u - Actually, It would be best for them to opensource all the code so the community can take over from where they have given up. It makes no sense for them to hoard the code as if they're going to resurrect it someday with something newer because it'd be far to stale by then.
- JanHussaarts2Luminary
I bought the RN426 in May 2020, so I still have over 1 year of support.
I wonder if Netgear is allowed to distribute updates that change the functionality of their NAS devices in such a way that they become unuaseable.
I’m actually quite surprised there’s not been more of an outcry about the OS-6 update. It really seems ludicrous to me that users cannot now easily update, or install, apps via what was ‘an easy to use interface’ and that users may have to resort to, what feels to me like, ‘hacking’ - using SSH ‘root’ access and the such-like to keep Apps updated and maybe more secure.
It’s not like these NAS storage devices were ever cheap to buy in the first place either.
I’ve decided to just never ‘knowingly’ buy a Netgear product again. They are not so exclusive, that I can easily go elsewhere for a similar product Netgear now manufacture, but that’s just my own personal way of retribution for this. I doubt that it will ever bother Netgear that much, but I really do want them to know that they have lost me as a potential future customer. It’s just my own way of dealing the issue
Just to clarify too, I’m not advocating others follow my chosen path, that’s entirely a matter for the individual.
I just see the upgrade as rather a poor decision, particularly from a customer-relations perspective.- JanHussaarts2Luminary
From a hardware point of view, the Ultra 6 and the RN246 I own are great devices. They run forever without ever going down. From a software point of view it has been lousy for years now. I managed running some newer stuf due to the products I could get on https://rnxtras.com/ . The owner, Stefan, stopped shortly after 6.10.8 was released. On his farewell page he writes
It wasn’t and still isn’t an easy decision but with the latest changes that came with ReadyNAS OS 6.10.8 Netgear made it more than clear that they no longer really care about the ReadyNAS product line.
How right he is!
- not_tellingAspirant
Hi
No idea if anyone can help, I stupidly updated from 6.10.09 to .10 hoping to get any security fixes, but now SMB is broken.
Anyone experienced the same? Windows logs show the following:Smb2DiagReasonISC.
Error: The attempted logon is invalid. This is either due to a bad username or authentication information.
FTP works fine (with the same accounts), tried using admin, tried creating a new account, a new share, setting permissions to everyone, no luck. Restarted SMB multiple times, tried a different VM
Date and time are correct, but I cant see any other logs on the nas
Are you saying you cannot download the log zip file?
That is odd, and not something I've seen reported here before.
Have you tried mapping the data volume to a drive letter using CMD as a test?
net use * /d /y net use z: \\nas-ip-address\data /u:admin nas-admin-passworduse the real NAS IP address and admin password of course.
You could also downgrade back to 6.10.9 and see if that restores normal operation.
- not_tellingAspirantHey thanks for responding, I haven’t tried downloading the logs I thought it would just be what was shown in the console, which isn’t much
Tried mapping, if I purposely put in the wrong password I get an “incorrect user name/password error”, so it’s accepting the right password just not connecting
Not a windows issue because even my iPhone can no longer browse.
Will have to try a downgrade , maybe after 12 years it’s time to upgrade …
