LeRouteur
Jun 13, 2021Aspirant
ReadyNAS OS 6.10.5 crashing iSCSI
Hi, After upgrading the ReadyNAS OS to its latest version 6.10.5, the iSCSI targets I created keep disconnecting from my server, making the virtual disks running on the LUNs unreachable. It happene...
Jun 13, 2021Guru - Experienced User
LeRouteur wrote:
I tried to downgrade to 6.10.4, but the NAS is stucked at: "Rebooting, see you soon".
Did you try clearing the browser cache and connecting again?
LeRouteur
Hi,
I don't think there's anything linked to the browser cache since the message I mentioned appears on the NAS screen.
- StephenBJun 13, 2021Guru - Experienced User
LeRouteur wrote:I don't think there's anything linked to the browser cache since the message I mentioned appears on the NAS screen.
Thx for clarifying. If you are still seeing that message, you'll need to forcibly shut down, and then try powering up again. Then check to see what software the system is running.
- LeRouteurJun 13, 2021Aspirant
Hi,
I forcibly shutted it down, but the 6.10.5 is still there.
Strange issue, isn't it? Haha
- SandsharkJun 13, 2021Sensei
Are you getting any warnings about a full or nearly full OS partition? That can cause a host of odd, seemingly unrelated issues, including the inability to upgrade/downgrade the OS..
Your NAS was stuck shutting down because some process was not stopping properly. That same process may be the issue with iSCSI. If you shuit it down again, does the same happen? If so, can you run top via SSH and see if you can see what process that is?
