givememynamebak
Jan 18, 2019Luminary
ReadyNAS OS 6.9.5
Why doesn't ReadyNAS OS 6.9.5 show up automatically for update under Long-Term Support or Stable? It's been almost 10 days since it's release...
I also tried to do this update manually and g...
givememynamebak
Jan 19, 2019Luminary
Thanks for the reply StephenB Yes, it updated when I rebooted. I was on 6.9.4 Hotfix 1. The right beta version is available, but at the very least they should put it on Stable I would think for those who want it sooner vs Long-Term Support.
Jan 20, 2019Guru - Experienced User
They always post a new release for manual updates first, and then put it on the update server after a week or so.
Not sure if the version in the beta update is the released version or the final release candidate.
