sergio_fucchi's avatar
May 05, 2019
ReadyNAS OS 6.10.0 (Hotfix 2) - problems after update from 6.9.5
Hi.
A big problem after upgrading from version 6.9.5 to 6.10.0.0 / patch 2).
Until the previous firmware version in case of power loss due to power failure, the NAS restarted without any problems by going online after a few minutes.
Now, with 6.10.0.0, instead, in the case described above, after booting, the system performs a new resynchronization of the data! So about four days of work for a simple jump of the electric current!
Why all this ??
  • The NAS will resync if it detects that one of the disks is a bit behind the others (due to missed writes).  But when the disks are out of sync, it is also possible to lose data (depending on what writes were missed).
    I always recommend a UPS.  Lots of data loss stories here start with an unexpected power cut.
  • It has nothing to do with the OS revision (at least, not since a change made several versions back), it has to do with what your NAS is doing when the outage hits.  It sounds to me like you really need an UPS.
    • sergio_fucchi's avatar
      sergio_fucchi
      Guide
      Maybe you didn't understand well what I wrote. I have had this NAS for five years and in all this time it had never happened that after a power surge on reboot a resynchronization started. It only happened after updating to firmware 6.10.0: is it just a coincidence? I don't think so.
      • StephenB's avatar
        It is common for the NAS to do a resync after an unexpected power cut.
ProSupport for Business
