sergio_fucchi
May 05, 2019Guide
ReadyNAS OS 6.10.0 (Hotfix 2) - problems after update from 6.9.5
Hi.
A big problem after upgrading from version 6.9.5 to 6.10.0.0 / patch 2).
Until the previous firmware version in case of power loss due to power failure, the NAS restarted without any ...
- May 07, 2019
The NAS will resync if it detects that one of the disks is a bit behind the others (due to missed writes). But when the disks are out of sync, it is also possible to lose data (depending on what writes were missed).
I always recommend a UPS. Lots of data loss stories here start with an unexpected power cut.
sergio_fucchi
May 06, 2019Guide
Maybe you didn't understand well what I wrote. I have had this NAS for five years and in all this time it had never happened that after a power surge on reboot a resynchronization started. It only happened after updating to firmware 6.10.0: is it just a coincidence? I don't think so.
May 06, 2019Guru - Experienced User
It is common for the NAS to do a resync after an unexpected power cut.
