peet1
Mar 21, 2013Guide
ReadyNAS OS 6 already running ReadyNAS Pro hardware?!?!
Okay now I'm a bit confused JabbaTheHutt is saying in the announcment post http://www.readynas.com/forum/viewtopic.php?f=1&t=70131 that: Even with the factory default option, there are hardwa...
TeknoJnky
Mar 21, 2013Hero
an initial guess, might be that the os6 is too big to fit in legacy devices flash ram.
but that is just a wild guess, there may be other hardware differences (network cards/sata/usb controllers etc that would require driver support).
That said, there is likely little doubt that os6 has been in development for a long time and was probably developed on pre-os6 hardware.
