rapple's avatar
rapple
ReadyNAS os 6 Snapshots
IS there a good description anywhere of how snapshots are implemented? I ask because they are taking up a lot of space on my system and I want to get rid of some, BUT I want to understand whether a s...
  • Sandshark's avatar
    Jan 28, 2020
    They are standard BTRFS snapshots, so you can Google for more info.
    They consist of additional pointers to data that has not changed and unique data that has changed since the snapshot.  So, they take up some additional data, and the amount taken up depends on how much "churn" there is in the share.  Shares used for tempaorary files or those with files that are changed often (like some databases) are not good candidates for snapshots unless you can accept the space useage.  Defrag is also contrary to snapshot size management.  Data moved for defrag will have the old location of the data retained in snapshots and the new in location the active files.  While it's equal data, it's not "the same data", and the snapshot system only knows whats not the exact same.
    There was a version update some time back that could cause retention of "invoisible" snapshots.  If you think you could be suffering from that, the only solutions are via SSH (done yourself or by paid Netgear support) or destroying and re-creating at least the share, if not the whole volume.  In doing that, you lose all yor snapshots, of course.
ProSupport for Business
