olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
ReadyAS
Jan 15, 2014Guide
StephenB wrote: You can do (5) - my RN102 shares the same UPS as my NV+ and duo v1.[...]
So, should I try connect UPS to USB of my Ultra with OS6 and share for Pro and NV+?
StephenB wrote: [...]On (2) If you have a mouse with a wheel, you can see most of the SMART stats from the UI (the SMART window scrolls). But if not, you do need to download the logs. I agree that is a pain.
Thank you! Yes it's a pain. For instance I can't do it on my laptop, I should connect the mouse.
In my opinion NTG should change it in newer versions - SMART parameters easily presented.
