olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
Jan 16, 2014Guru - Experienced User
Not sure either (particularly for Win7, which is what I am using).
mdgm wrote: If you have a Mac you can easily use two finger scroll on the trackpad. Not sure if there is an equivalent for Windows.
Even if there is a way, the fact that the popup scrolls at all is not obvious. They should make this popup work like all their other scrolling windows. It needs to be easy to see the SMART stats.
