olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
xeltros
Nov 17, 2014Apprentice
AFAIK you only have a timer to switch off then back on. Still there is the possibility to do it via SSH. The shutdown command is rn_shutdown, I believe that either "at" or "cron" will let you automate the shutdown process. If you have SSH enabled, you can try this, otherwise if this is something that you don't need that much (or can cope with the on/off timer), I would advise not enabling SSH as this can cause some problems with the warranty (though I don't see Netgear complaining for a simple call to a command at a specified time).
