olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
mdgm-ntgr
Nov 17, 2014NETGEAR Employee Retired
If you're not comfortable with SSH, a better way would be to run a script on another box that calls the shutdown command via the Dashboard. The disadvantage of that is you would need to hard code the login credentials for the Dashboard in the script.
