olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
Retired_Member
Apr 24, 2015The ability to select more than 1 Snapshot at a time to be deleted would be an advantage. Its very slow deleting 1 at a time, a simple check box above each timestamp/marker would suffice then hit Delete.
On the Snapshot schedule facility, add in the Option of Monthly.
Also the ability to share Sub folders as I posted before would be great.
Thanks
Thanks
