olest
Aug 13, 2013Guide
Readynas OS6 future requests
1) Snapshot function on Home folders. 2) Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots ...
itsjasper
Jun 26, 2015Luminary
I'd be quite happy with a CPU / RAM used counter (like the Synology DSM has), and surely it would be trivial to add those counters into the performance section?
Talking of which, being able to select which performance counters are shown, and being able to reorder of those counters would be beneficial. eg: I have no need for utilisation over time, and look at IOs rarely. CPU, temp and data rates are more important to me. Also making the counters 'remember' if they are in a minimised or viewed state, ideally past reboots.
Otherwise, have a basic / advanced toggle for the performance section and have simple dials or bars in the basic section, and put all the good power user stuff and RTG graphing in advanced.
And to finish off with more of a unicorn request than one for a pony :D - a VirtualBox / Docker app for higher-specced units would be amazing.
