computim
Feb 14, 2026Luminary
ReadyNas Pro -100
Acquired an Old ReadyNas pro 6 -100 it is running OS6 6.10.9 2GB memory and the 1.8ghz processor Bios is version 1.6 I'd like to update the Bios to version 2.0 for the higher speed FSB memory and...
- Feb 16, 2026
computim wrote:
The command Sandshark (lsblk) provided does not function in Tech Support Mode.
FWIW, it was my suggestion. But good to know, as other users will likely run into this. Tech support Mode is missing a lot of commands.
I think in most cases the USB drive will be right after the last internal disk (so sde1 if there are 4 drives in the system), and the flash will be the one after that. But "most cases" isn't the same as all cases. sdc1 was the drive in Sandshark's writeup because he was testing on a Pro 2 (presumably with two drives installed).
But this might not be always true, and it is important to find the correct drive.
computim wrote:
The write up provided by Sandshark was fully executed and the VPD file is now on the USB drive successfully.
Great!
Sandshark
Feb 15, 2026Sensei
The easiest way is to remove your volume with power off (marking drives to put them back as they were), use a spare drive to convert back to OS4.2.x, install the BIOS update package, convert back to OS6, then re-install your drives (again, with power off).
