gazgaz
Dec 20, 2011Aspirant
readynas pro 12TB is full of movies
My Readynas pro is full of movies. I have need of a new NAS so am looking at all the options. I bought the pro a few yrs back as it was said to be the fastest at the time. I have never had it miss a b...
mdgm-ntgr
Dec 20, 2011NETGEAR Employee Retired
You can have multiple NAS units on the same network. Personally I would recommend the ReadyNAS Pro 6 (RNDP6000-200), which is the second gen Pro and has a faster CPU than what's in your ReadyNAS Pro.
With two ReadyNAS you're pretty much guaranteed for them to work well together and for users on here (or NetGear support) to be able to solve problems such as backing up data between the two NAS units
If you get a different brand NAS it will likely have a different feature set. Mostly they should work fine together and problems should still be able to be solved.
