Kenn
Sep 04, 2017Aspirant
Readynas Pro 2
I have a Readynas Pro 2 which I did an upgrade on but now I cannot access the admin web page. The shares are still accessibly and I can ssh to it. Raidar connects and shows firmware 6.8.0. but apache...
Kenn
Sep 05, 2017Aspirant
After much hunting I find a post which looks like the same as I have:
I get to step 5 but "apt-get install aptitude" returns lots of warnings of missing dependencies so I stop there.
/usr/lib/apache2/mpm-worker is empty but looks like it should the apache2 executable.
Anyone have any suggestions as to what my next move should be please?
Sep 06, 2017Guru - Experienced User
Does https://nas-ip-address/fwbroker respond? Use the real IP address of the NAS of course.
BTW, there's no point in trying Netgear support, since your configuration (OS 6 on a legacy NAS) isn't supported.
- KennSep 06, 2017AspirantHi Stephen, I get no response from https://ip-address/fwbroker.What would be the best way to copy all the data to an external USB drive? I think I will try to make a backup then do a factory reset and see if that will get me somewhere.
- StephenBSep 06, 2017Guru - Experienced User
Kenn wrote:
What would be the best way to copy all the data to an external USB drive? I think I will try to make a backup then do a factory reset and see if that will get me somewhere.I'd copy the data over the network (since you still have share access).
A factory reset is brute-force, but that will fix it.
- KennSep 13, 2017Aspirant
I did a OS reinstall which fixed the problem without loosing any data or configuration. The only thing that changed was the admin password reverted back to the default. I'd call that a good result and I'm happy.
