payyy
Feb 25, 2020Aspirant
ReadyNAS Pro 4 stuck at booting after factory reset
Hi, ReadyNAS was working just fine. Simply did a factory reset with new drives since the previous volume could no longer be expanded further. Process went as expected, created a new volume with RAIDa...
payyy
Edit : Missed the text ERR : Could not properly extract quickly showing up on the LCD. same happens during a OS Reinstall. I have tried to do a USB Recovery but it just stalls with the cursor flashing on the LCD.
Searching older posts for similar issues, I see that most similar cases were resolved by mdgm-ntgr, which is now gone, I assume there is a telnet command to clear the corrupt flash and get a fresh firmware on the device.
anyone know how?
thanks
Feb 26, 2020Guru - Experienced User
One of the current mods ( JohnCM_S or Marc_V ) might be willing to help. You can also try paid support ( my.netgear.com). Ask for per-incident support.
