payyy
Feb 25, 2020Aspirant
ReadyNAS Pro 4 stuck at booting after factory reset
Hi, ReadyNAS was working just fine. Simply did a factory reset with new drives since the previous volume could no longer be expanded further. Process went as expected, created a new volume with RAIDa...
JohnCM_S
Feb 26, 2020NETGEAR Employee Retired
Hi payyy,
Can you boot the NAS in Tech Support mode? If you can, please boot it in Tech Support mode then send to me the 5-digit code via private message.
payyy
Feb 26, 2020Aspirant
Hello,
It did boot in tech support mode yesterday... and now I cannot get back to the boot menu, I guess I must have bricked it trying the usb recovery too many times
thanks for trying to help
- JohnCM_SFeb 26, 2020NETGEAR Employee Retired
Hi payyy,
You can try removing the disks first then try booting the NAS in Tech Support mode. If it successfully boots, you can reinsert the disks.
