Vinnie_D's avatar
Vinnie_D
ReadyNas Pro 6 - Stuck at Booting up - Shows 'ReadyNas'
I just want to start out by saying hi to everyone and would appreciate any help that anyone can offer.
I am relatively new to storage devices and unfortunately I inherited this headache as I was given this unit. At start up this unit seems to hangup on boot mode and the only thing I am able to see in the front is "ReadyNas". I have tried to reset the unit but to no avail.
I have also tried to set up a USB recovery stick but that also seems to get  when I hit create. The only thing I see at that point is "Start to prepare USB recovery flash".  Once thing that I did notice is  I get to the drop box "Select Firmware Image" nothing shows up. Is this the problem. I have tried using a different USB Drive, but also with the same results.
Can anyone offer any suggestions.
  • StephenB's avatar
    Welcom to the forum
    Normally Netgear support discourages routine use of USB recovery on OS 4.2.x ReadyNAS.  So maybe see if the Netgear mods have some other suggestions.
    I have a couple of questions -
    (a) if you install RAIDar on an PC, does it give you any more status information on the NAS?  RAIDar is available here: http://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
    (b) Do you have disks installed in the ReadyNAS?  If so, what models?
    (c) have the disks been tested recently with vendor tools (seatools for seagate, lifeguard for western digital).  These tools (unfortunately) are windows-only.
    • Vinnie_D's avatar
      Vinnie_D
      Thanks for your quick responce,
      I do have Raidar on the pc and what is shows on start is the raidar help menu with the blue light blinking and stating that Background Taks active - a lengthy background task such as a system update in progress, also the red life support mode is blinking.
      I do have disks installed - 5 WD 3.0TB - Model WD30EFRX - 68AX9Z0
      I have not tested the disks at all.
      I do have a windows 10 computer, but how would I go about testing the drives is they are in the Nas unit. Can I connect them directly to the computer?
      • StephenB's avatar
        You'd need to remove them, and put them into the PC.  You can use a USB->SATA adapter or USB enclosure for this.
        Do you care about the data on the drives, or is this the initial setup?  If you don't care, you can aslo use the quick zeros function in Lifeguard to unformat the drives.  Then reinsert them and power-up - the NAS will do a factory install.
        Also, if RAIDar is giving you the firmware on the NAS, please let us know that it is.  It could be either 4.2.x or 6.x.x
ProSupport for Business
