peladon
Oct 31, 2014Aspirant
ReadyNAS PRO 6 / Western Digital Red WD40EFRX
Advance note: I'm ready to be told 'it isn't in the HW Compatibility List - go away' (blush). I've got a ReadyNAS Pro 6, all bays full, with a RAID 6 Volume. After disk failures, I added (at differen...
vandermerwe
Oct 31, 2014Master
What were the sizes of the disks in your original raid 6 volume, before you added the first two 4tb wd drives?
When you added the subsequent four 4tb drives, did you add them all at the same time or one at a time?
Do you have a backup?
What firmware are you running?
