peladon
Oct 31, 2014Aspirant
ReadyNAS PRO 6 / Western Digital Red WD40EFRX
Advance note: I'm ready to be told 'it isn't in the HW Compatibility List - go away' (blush). I've got a ReadyNAS Pro 6, all bays full, with a RAID 6 Volume. After disk failures, I added (at differen...
peladon
vandermerwe wrote:
Even if you had not exceeded the limit, you would not have been successful at adding 4 new disks at the same time while preserving the volume. With raid six the maximum number of disks you could remove and replace at one time would be two,
Aye - that bit was just me being dumb. I thought (old memory) that if the NAS didn't see a 'good' volume, it defaulted into setup mode. If I'd remembered I had to do a factory reset, I wouldn't have had to waste your time reminding me things I should have remembered :-).
