peladon
Oct 31, 2014Aspirant
ReadyNAS PRO 6 / Western Digital Red WD40EFRX
Advance note: I'm ready to be told 'it isn't in the HW Compatibility List - go away' (blush). I've got a ReadyNAS Pro 6, all bays full, with a RAID 6 Volume. After disk failures, I added (at differen...
vandermerwe
Oct 31, 2014Master
No worries.
I edited one of my previous posts in response to StephenB's post which reminded me that you won't be able to factory default straight into raid 6, so you'll need to do it ( factory default) with 5 disks, then add the 6th after the volume has been set up.
