ccc1997
Sep 20, 2012Aspirant
ReadyNas Pro 6 + Which Hard Disks?
I prices are getting low enough that I can finally get a RNP6. I just missed a really good deal on NewEgg that I read about in the forums; if it comes back i will grab one. I expect the prices to dr...
Sep 20, 2012Guru - Experienced User
No. You need to do that on a PC (or an x86 Mac, using the Seagate boot CD).
ccc1997 wrote: The Seagate disk states that a specific firmware needs to be used; can I upgrade the firmware (if needed now or in future) easily while installed into a RNP?
