a-c-w
Jul 19, 2023Aspirant
ReadyNAS Pro 6 failed drive and lost volume / shares
I have a ReadyNAS Pro 6 RNDP6000 with 6 disks. Disk 3 started failing, and I pulled out disk 6 by mistake, put it back in, and then pulled Disk 3 and put in a new drive. Now the volumes and shares ...
a-c-w
Aug 16, 2023Aspirant
Thanks Stephen. I ssh'd into the NAS, and I'm getting
"Could not chdir to home directory /c/home/admin: No such file or directory"
and then the ssh session ends. That kind of make sense since no volume is recognized. When I boot the NAS, I get
"Volume scan failed to run properly."
and then this message :
"The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume." - followed by a list of shares.
Any suggestions on what I can try next?
Aug 17, 2023Guru - Experienced User
I'll need the log zip file to tell you what to do next. Put it into cloud storage, and PM (private message) me the download link. Please make sure permissions allow anyone with the link to download. You can send a PM using the envelope icon in the upper right of the forum page.
- a-c-wAug 17, 2023Aspirant
Thanks Stephen, just sent PM.
