a-c-w
Jul 19, 2023Aspirant
ReadyNAS Pro 6 failed drive and lost volume / shares
I have a ReadyNAS Pro 6 RNDP6000 with 6 disks. Disk 3 started failing, and I pulled out disk 6 by mistake, put it back in, and then pulled Disk 3 and put in a new drive. Now the volumes and shares ...
AnishaA
Aug 31, 2023NETGEAR Employee Retired
Hello a-c-w ,
And welcome to the NETGEAR Community! 🙂
Have you shut down the NAS while pulling out the disk?
If possible please share the disk logs and volume logs to check further
Have a lovely day,
Anisha A
Netgear Team
a-c-w
Aug 31, 2023Aspirant
Thanks Anisha, just sent you PM.
- AnishaASep 04, 2023NETGEAR Employee Retired
Hello a-c-w ,
Shut down the NAS and try to remove al l the drives and insert in the different slots and check for the status.
Have a lovely day,
Anisha A
Netgear Team- a-c-wSep 05, 2023Aspirant
Hi Anisha,
Not sure what you mean....
Do you mean shut down the NAS, and then take out all the drives, and then put them back in (in which order? ) and then power back on?
- AnishaASep 06, 2023NETGEAR Employee Retired
Hello a-c-w ,
Yes, from the logs you have provided the device is not detecting the disks. So please shut down the NAs and try to remove all the disks insert them back and reboot the device manually.
You can change the slots and insert them back.
Have a lovely day,
Anisha A
Netgear Team
