kevsterrrrr
Apr 25, 2013Aspirant
ReadyNas Pro 6 Freezes x3 as of 26/4 in the one month
Hi, I have a couple of ReadyNas pro's in production serving a couple of NFS VMware environments with Terminal servers and SMB shares for 2 businesses with approx 8-10 staff at one site and approx 2...
kevsterrrrr
May 01, 2013Aspirant
Hi,
that sounds viable, in frontview the drives were listed as disconnected..after testing the drives and running some drive scans on them there are 21 bad sectors on one, the other drive seems to be all clear.
I'll replace the drive with the bad sectors and will probably reformat the good drive as ext4, upgrade the readynas in any case and change the cables!!
Thanks for all your help, i'll post back once i've replaced the disk, and updated the firmware..
Cheers,
Cheers,
- Jan 17, 2024Retired_Member
