wcasanov's avatar
wcasanov
ReadyNAS Pro 6 (RNDP6000) stuck at READYNAS screen after power failure.
I have a ReadyNAS Pro 6 (RNDP6000) that failed to recover after a power failure. This firmware on the device was upgraded to OS6, currently running 6.10.10 when it died. I have replaced the power supply, CPU and ram without any change. I cannot access the device via raidar, although it appears to connect to my network (green light on switch), no ping either.
Since it was upgraded from OS4, I was not sure which USB recovery tool should be attempted, if any. Any help would be greatly appreciated, especially since this is a legacy product running an unsupported configuration.
  • StephenB's avatar
    Is the LCD functional?
    Try powering down, and removing all the disks (labeling them by slot).  The power up the NAS diskless, and see if you can ping it.
    • wcasanov's avatar
      wcasanov
      Tried booting without disks, no luck. Network lights have now gone out, so it doesn't appear to initialize the network card anymore.
      • StephenB's avatar
        Not a good sign.
        You could try an OS reinstall, but I don't think it will resolve anything.
        If you do try it, you use the OS-4 reinstall process, but substitute your OS-6 firmware.
ProSupport for Business
